Ok, so..
1997 Acura Integra..
On lower ambient temp days, say 75F and below, I can drive around all day long with the A/C on and it never stops pumping cold air.
When the temps start climbing, I can drive roughly 45 minutes on the highway and the A/C will slowly fade out and stop working and start blowing ambient air.
I use it as a daily beater, commuter and I can almost predict when the A/C will stop working on the way to work during the warmer days. When I get off and drive home in the evening, the A/C works fine.
I've leak tested the system with the UV dye stuff and cannot locate a leak.
Surely we have an A/C expert in the group?
TIA
TIA
