A good friend of mine has a 1999 Ford Ranger Supercab 4x4, manual trans with 250k miles and he will give it to me for $2500. He bought it with 225k when he worked at Carmax a few months ago.
He bought it because he had a Carmax mechanic look it over and he said one of the bolts or straps or something or rather that holds the engine to the mounts was different than from factory. He said this likely meant the engine was not factory either so it had less miles on it than the odometer was showing.
My friend has had no problems with it in the past 25k miles. The throwout bearing could be going bad but that's not too tough of a fix I don't think. Then again it could just be some kind of clutch rattle that is harmless. The clutch seems to be in great shape and isn't slipping at all.
Bluebook value for the thing is like $4000 but that sounds high to me. I was wondering how many of you would take the plunge on a 250k mile truck for $2500. Also, is there an easy way to tell if the engine is original? I'm sure there has to be a serial number somewhere but I don't know where.
Eta: My friend is a meticulous maintainer just like me. Oil has been changed every 4k with M1 Clean 5000 since he has owned it. Coolant flush was done and manual transmission fluid was changed. First thing I would do is change the fluid in both diffs. The 4wd STILL works!
