Around 100k got intermittent oil pressure lights.
Soaked and cleaned pickup through drain hole - went away for awhile.
Now at 150K, opened up, new plate gasket, and now into bearings.
Pickup was 6/7s blocked with 'crystal'-y debris, and some (5 sq in) on block near pickup - but not a sludged up motor at all.
All rods down to copper, mains not so bad, except #3 - the thrust bearing - and it's crank scored.
All seem worn, not foreign deposits/embedded.
I cleaned the #3 journal a tad, back polished another tad, and fitting 1's and 0's mixed to all positions.
Rods smelled horribly of fuel (started project just after an oil change, that was also fuel-y.)
New pump ready to go in; soaked, reamed, and picked pickup clean.
What causes a crystal-y debris?
Will fuel thin oil (but yet not cause overfill) and 'cut' bearings?
Can plate gasket somehow affect oiling or bearings?
