Chevy, if you private message me your email address, I'll shoot you an email and I will get things ready for you to post here by you forwarding your black stone.
OTOH, if you do it yourself. What I do is take previous 'code' text from one of the used oil analysis on the site. Copy and paste the relevant data inside the 'code' block/box. Paste it in notepad, if using windows, (Start > Run > notepad[enter]), then I'll edit with my data. Copy THAT from the notepad, and paste it in a new message on here with (code) my information ready to paste (/code)
It comes out as so...
Code:
but you must use [ and ] in place of the ( & ) in the
above, or it converts what I typed above into a code
section like this instead of showing you the format, and you
wouldn't see the particulars. Of course you can always in full
screen mode use the #/symbol column which includes the code
option for any highlighted test you are preparing
for instance, here is the data I want to have typed out in code:
OIL AMSOIL ASL 5w30
MILES IN USE 9,842
MILES ON UNIT 126,954
SAMPLE TAKEN 06/09/12
ALUMINUM 5
CHROMIUM 2
IRON 19
COPPER 16
LEAD 29
TIN 5
MOLYBDENUM 132
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 5
BORON 29
SILICON 14
SODIUM 11
CALCIUM 3407
MAGNESIUM 275
PHOSPHORUS 662
ZINC 710
BARIUM 0
SUS VIS 210ºF 60.9
cSt @ 100ºC 10.47
FLASHPOINT ºF 410
FUEL% ANTIFREEZE% 0.0
WATER% 0.0
INSOLUBLES% 0.2
TBN 1.4
...now with it 'wrapped' in code (use the # symbol drop down menu in message creation while the above is highlight and once posted it comes out as:
Code:
OIL AMSOIL ASL 5w30
MILES IN USE 9,842
ALUMINUM 5
CHROMIUM 2
IRON 19
COPPER 16
LEAD 29
TIN 5
MOLYBDENUM 132
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 5
BORON 29
SILICON 14
SODIUM 11
CALCIUM 3407
MAGNESIUM 275
PHOSPHORUS 662
ZINC 710
BARIUM 0
SUS VIS 210ºF 60.9
cSt @ 100ºC 10.47
FLASHPOINT ºF 410
FUEL%
ANTIFREEZE% 0.0
WATER% 0.0
INSOLUBLES% 0.2
TBN 1.4
