I just bought a ’98 Subaru Legacy Outback 2 days ago with 147989 miles on the clock. To make a long story short air is getting into the cooling system from combustion. Suspect head gasket need replaced. I bought the car with this disclosed at the used car lot. It has been 7 years since my last Subaru head gaskets job. Any pointers from you guys on what to watch out for on this 2.5L that is outside the norm when I get this engine apart? When I pull the engine to do this repair any pointers there also? I will of course have the machine shop crack check the heads as well as do a valve job. Should I go OEM on the gaskets and parts or is felpro brand from the parts houses good enough. Last question, are the rods and main bearings worth considering at this mileage? Alldata shows splitting the engine to replace both rod and main bearings. That is deeper than I want to go but I will if I should, this car is super clean and runs great and I bought it at a very reduced price. I am KEEPING this one!
Shoot some insight my way Subaru guys, I work on these from time to time I just do not go this deep on the engine very often. They seem to run forever!
