'98 Plymouth Voyager - ATF +3 or +4?
Long Island
Greetings - we have a '98 Plymouth Voyager with the Mitsubishi 3.0 V6. I had the automatic transmission rebuilt about 15K miles ago and figure it's time to exchange some old fluid for new. I have been trying to figure out which AT fluid I should use. As I have a 1998, it appears to be a pivotal year. Some websites recommend that if it's older than 1998, one should use ATF +3. Yet I have also read that ATF +4 is the stuff to use as it supercedes ATF +3.
Any recommendations as to which fluid I should use? The manual says ATF +3 7176.
I have read to use what the manual recommends, but I have also read that ATF +4 is better replacement.
Can any Chrysler owners set me straight?
I don't think +3 is being made anymore. Anthing on the shelf is more than likely old stock. I would use the walmart +4 at $2.97 a quart. It's a better fluid and backward compatible.
+4 is the proper fluid for that tranny. Choose the cheapest +4 brand(usually supertech) as every one of them is exactly the same. Same basestocks, additives, everything.
