98 Camry electrical problems...
los angeles
Just got this car, a 98 camry 4cyl.All lights flicker,like a steady pulse.I've replaced the alt and the battery,no luck.The battery light will stay on for a few minutes after i turn it on,even if i rev it up to 1500.If I hit the brakes or use the turn signal,the stereo turns off and on really quick.If i do this with the headlights on,the headlights dim a good amount.I've already cleaned all engine grounds,batt cables look good.Kick panel grounds cleaned and checked.HELP!!! lol
Have you popped out the entire fuse panel under the hood? You gotta use a 10mm wrench. Make sure every connection under there is tight, and none look burned. Don't be afraid to pop the bottoms off the underside of that panel to get a good look. Get a test light and test all fuses, even if they look fine.
Nick beat me to it!
I was going to suggest a cheap multimeter off ebay and a Bentley or a Haynes for its wiring diagram.
Half a day at the most
I had a similar problem with my import ,,,,Carefully inspect your brake light bulbs ( and all other bulbs )---I had a bulb that where the filament collapsed and was making a direct short in the electrical system
Unplug the alt for a minute and drive around just on the battery. Bet this will fix it. Suspect your alt has a bad diode.
alt's been replaced with a known good one.same results
BINGO!!! I think this was it.The plastic from the connectors under the block looked like they got hot enough to melt onto the metal they bolted on to.One or 2 were loose and i tightened them up.I drove around for a while and no more symptoms!!! Thanks,Nick!!!!
No problem! I have the same car and changed the timing belt. Stupid me didn't disconnect the battery and the alternator positive that leads to the battery grounded on the exhaust and I didn't think much of it. Alternator fuse blew and I had to take out that panel and unscrew the fuse. My symptom was no instrument cluster.
