Originally Posted By: lucerne06
Thanks guys, i am going to change the timing belt and thought that if the pump is run buy the timing belt, then I would change both..but since I can get to the pump without having to take the cover for the T.B off, then I will just let it alone.
As mentioned above, while the pump is not driven by the timing belt, much of the same work to GET TO the pump is shared with the timing belt, so you might as well do the pump if you have high mileage (over 200K miles.)
I'm at 235K and I think my pump is now just starting to make some noise. Sadly, I just had the timing belt done last spring, so I likely be paying for much of the same labor again when it's time to do the pump.
