Hello everyone.
I always research everything before buying and usually find myself here when it comes to oil. So why not just ask, because I always fall down the rabbit hole and this time found myself reading a thread about used oil being superior to new. lol. Anyway!
I just bought a clean 97 cummins 12 valve with nv4500 dana 80 limited slip rear dana 70 front with 1009K on it. I plan on keeping this truck forever and have already located some Castrol Syntorque for the 5 speed but I'm not sure what oils are best for my differentials and 241 transfer case. The previous owner always used rotella dino so I see no reason to change unless someone can change my mind. Should I consider a aftermarket oil filtration system?
Id like to hear your opinions on any or all of the oils you would use in this truck, but mainly the differentials and transfer case.. I plan on light towing and occasional short trips in Iowa.
Thanks!
Thanks!
