I just looked this part up on RockAuto, I do not know about the part that is listed as Control Module Relay as they don't show a picture for it......on the Mercury Sable OR the Ford Windstar for 1996.
However, when I scroll down to Powertrain Control Module Relay, they show a picture....and that is the CCRM.
These are both under Switch/relay
Under Cooling system, the Cooling Fan Controller lists a picture that also matches my CCRM.
I have replaced this part on my '96 windstar.....so I recognize it.
The windstar an sable are very similar......the CCRM contains the Fuel pump relay, Radiator Low speed fan relay, the Radiator High speed fan relays.
I looked up the "Cooling Fan Controller" in the Alldatadiy manual for my '96 windstar, and it is the CCRM.
They also list the same part as "Integrated Control Relay Module"
Y2K Ford sells parts at a discount......they list the CCRM at $97.14 (vs list of $140), they call it "ECM Relay", I bought mine from them....and it was the correct part.
However, when I look under 1996 Mercury Sable, they don't list the ECM relay. I would recommend giving them a call or send them a email and ask if the windstar CCRM (ECM relay) is the same as the one used in your 1996 Sable.....as you may be able to get genuine OEM for less money.
They have a provision for asking right from their website.
Wouldn't it be nice if they stuck to the same name?
