Guys the check engine light came on my car. It's up for emission check ( yearly ) . I just did a complete tune up on this car to try to get the light to go out /corrected. I replaced the spark plugs, & plug wires. Also the PCV and EGR valve. Air filter and oil change. I serviced the transmission ( oil & filter change also ).
The code that won't go away is P-1443 . I was told by the guy that pulled the code it was the evaporative Emission Control system valve . *** !!!!!!!!!!! He told me to check the O ring on the gas tank. And also asked if the gas cap is on real good. I have always had a locking cap on it but I came home and put the Factory cap I saved back on. Maybe the Stant cap started leaking some what ??? But anyhow any help yall can give me is appreciated. TIA Oiler.
