94 Formula Lt1 216,830 on odo. 10066mi on oil in 5 months. 3qts each M1 0-30 and 0-40. this is the thinnest oil this motor has seen since before 100k.
It was run during one of the coldest winters on record for MA.
Oil M1 0-30/0-40 M1 10-30/15-50
Miles on oil___ 10066___ 10122
miles on unit___ 216830___ 206764
date___ 6/7/05___ 1/17/05
Auminum___ 6___ 5
chromium___ 3___ 2
iron___ 36___ 26
copper___ 4___ 4
lead___ 12___ 4
tin___ 3___ 1
moly___ 87___ 54
nickel___ 1___ 2
mang___ 0___ 1
silver___ 0___ 0
ti___ 0___ 0
potassium___ 2___ 0
boron___ 151___ 100
silicon___ 12___ 7
sodium___ 10___ 7
calcium___ 2888___ 2226
magnesium___ 66___ 157
phosphorus___ 895___ 681
zinc___ 1008___ 766
viscosity___ 67.6___ 75.5
flash___ 425___ 410
Blackstone comments
TED: No problems showed up in the second sample from your GM LT-1. All wear continues to read
close enough to averages to be considered normal. This is excellent considering you are running the
oil about 6,500 miles longer than average. The mild increase in iron and lead is probably from
something operation (racing, city driving, etc..) and isn't high enough to call a problem, just something
to monitor. Silicon increased so you may want to look at your air filter. Other than that, things look
pretty good. No fuel dilution or anti-freeze showed up.
my thoughts.
This oil was too thin to protect my bearings from the abuse I give this car. Although it is a 100 mile a day daily driver it still gets drag raced occasionaly and generally beaten on. I am sure the couple of months of 0 degree cold starts did not help the numbers but the 10-30/15-50 mix gave much better numbers. Current fill is M1 TSUV 5-40. Hoping to use this year round.
hot oil pressure is 25 lbs at 550rpm compared to 17lbs with the 0w mix. I like this.
Any Comments from the board would be welcome.
Ted
Auminum___ 6___ 5
chromium___ 3___ 2
iron___ 36___ 26
copper___ 4___ 4
lead___ 12___ 4
tin___ 3___ 1
moly___ 87___ 54
nickel___ 1___ 2
mang___ 0___ 1
silver___ 0___ 0
ti___ 0___ 0
potassium___ 2___ 0
boron___ 151___ 100
silicon___ 12___ 7
sodium___ 10___ 7
zinc___ 1008___ 766
flash___ 425___ 410
Blackstone comments
my thoughts.
Ted
