I am looking at replacing the intake manifold gasket again due to a coolant leak. What are the correct Fel-Pro part numbers needed for this job? I'm looking at p/n MS98004T:
COMPLETE SET - VALVE COVER GSKT
& UPPER SET
INCL -
PERMA DRY PLUS
Another line item at the Federal Mogul sites uses the same p/n, MS98004T, but gives a different description:
COMPLETE SET
VALVE COVER GSKT & UPPER SET INCL
PERMA DRY PLUS INT MFLD GSKT INCL
M ENG CODE
Is there a difference between the two & the part number just doesn't reflect it? Or, is there another p/n that I'm missing to fix this repair for good?
What else will I need?
& UPPER SET
INCL -
PERMA DRY PLUS
COMPLETE SET
M ENG CODE
