93 grand prix tranny problem!
Elmhurst Illinois
A friend of mine has a 1993 pontiac grand prix with a 3.1L V6 and 4T60 trans. Anyway we were cruising around today and he stopped at a red light and when he went to go the car would not move at all nothing in forward or reverse gears
. It was working ok before that the only problem he had with it was it was a little slow to shift to 2ND gear then all of a sudden BAM it would not go into any gear. Anyone have any ideas what happened here? I was thinking that maybe the power transfer chain inside the trans broke also he had changed the transmission fluid and filter a couple of weeks ago. Would there be any possablility that the filter may have fallen off inside the trans? Other than that i dont have any idea why the trans would all of a sudden just stop working
4T60? or 4T60-E? There is a significant difference between them.
Without a teardown...its anyone's guess. How many miles, and was the fluid in bad shape when it was changed?
I had a similar problem. rough 1st and 2nd upshifts. one day, the flexplate broke. I couldn't shift at all. when I replaced this 20 dollar part, everything was fine again. does the car start and run? if it does, it's not the flexplate.
I just found out it has a 4T60-E trans. The car has 213k on it my friend said the fluid was a redish brown when he changed it and it had a normal transmission fluid smell it did not smell burned. The engine still starts and runs normally so it couldn't be a broken flexplate. Since it has an electronically controled trans could it be a computer related problem?
213k on an early-model 4T60-E is actually pretty good. Not built quite as good as the 4T60 and the electric parts (the reason for the -E designation) were somewhat more failure-prone.
Probably time to have the transmission in for a shop visit. No inexperienced amount of mucking around is going to get it working properly.
