After 7 years on any battery you’re living on borrowed time. It’s easier to replace at regular intervals. Like a Transmission fluid or differential change. Just needs to happen.
How is the rat doing?My battery is only 6 years old, but when it was one year old, a rat chewed a hole in it, and I patched the hole by gluing on a piece of plastic.
Worth investing $25 on an Ancel BA101 off Amazon and simply check the condition of your battery periodically. I got almost 15 years out of the battery in my Tundra...I just checked it every time I changed the oil and during a check it was showing some weakness...would never have known without the tester.After 7 years on any battery you’re living on borrowed time. It’s easier to replace at regular intervals. Like a Transmission fluid or differential change. Just needs to happen.
I’m in the “use a charger” camp for sure. Even if you only hook it up every few weeks it’ll help. I’ve been using mine, if not daily, at least a few times a week. Prior to replacing all my batteries back in December, I only did it a few times a year. I still had functional batteries 4 yrs later.
It can also be for "maintenance".What if someone is always doing very long drives? Wouldn’t that fully charge up the battery quite often and negate the need for periodic charging?
I have a battery tender for my 2018 Corvette (it was a factory option actually) and I use it during the cold months during times when I know I won’t be driving it for at least a week. But once I start driving it on a regular basis again I don’t use it because I take it on very long drives (150+ miles) on a regular basis. It’s still on it’s original battery.
I have never hooked up a battery tender to my Civic, as mentioned earlier it is still on the original battery (now 9 years old and with 165,000 miles on it) That car also sees a lot of very long highway drives.
9 years is excellent for those tiny little batteries Honda puts in their carsWhat if someone is always doing very long drives? Wouldn’t that fully charge up the battery quite often and negate the need for periodic charging?
It’s only 550cca as well so I’m amazed that it starts so easily even on the multiple days we’ve had here at -10C and colder9 years is excellent for those tiny little batteries Honda puts in their cars
