I do this when I’m riding my motorcycle in city traffic. If it irritates a driver…sorry, at least they see me.When it gets crowded during the day, I use high beams, which definitely helps. It makes people less likely to cut me off in traffic.
do you also have a starter battery under the hoodMy 2016 535d still has the original battery. I'll probably go with a battery from BMW when it's time to replace. I think one thing that helps BMW batteries last is that they're AGM, and they're in the trunk, away from engine heat.
No. There are terminals under the hood for attaching jumper cables but the only battery is in the trunk.do you also have a starter battery under the hood
I don't think that leaving your headlights on all the time while driving is having any significant negative affect on your battery life. High ambient heat is the number one factor. Also, I believe that the under-hood temperatures are higher on the newer vehicles. Living in TX I only get about 3 years out of my batteries regardless of who manufactured it or what vehicle it is in. IMO you are doing good to get 4 years out of your batteries living in AZ.Getting nine years out of a battery is incredible! In the desert, I could never achieve that. I usually de-sulfate/charge mine every 4 to 5 weeks.
I always run full lights, regardless of the time of day or location, to ensure I’m more visible to others. When it gets crowded during the day, I use high beams, which definitely helps. It makes people less likely to cut me off in traffic. I know this because people who are tempted to switch lanes too close in front of me, begin to merge but then hesitate when they see my high beams. Anyway, I think this is one of the reasons why I can only get about four years out of a battery.![]()
same supplier?I got over 8.5 years out of the original AGM battery in my F-150. I replaced it with a Motorcraft from the dealer.
View attachment 235820View attachment 235821
I'm not saying that you shouldn't have changed out the battery after 9 years. Indeed a good move!
I am curious as to, what does the battery voltage drop down to while starting the engine?
Dropping to 12.4v at rest sounds normal. But if it drops below 10v(or there about) while starting, then it is indeed time to start thinking about a new battery. Just sayin'!![]()
I've got one of those 2 year warranty Walmart batteries in my pickup that's pushing 5 years old. It still works, so I'm not going to change it.You're probably right. The old battery sat in my garage overnight and still measures 12.4v so it might have some life left in it. Understandably the owner didn't want to chance it as they drive their grandchildren around, especially with colder weather around the corner.
If it were my own car, I would've tested it more and carry a jump starter with me
A load test is a better indicator of whether or not the battery is good, or needs replacement.You're probably right. The old battery sat in my garage overnight and still measures 12.4v so it might have some life left in it. Understandably the owner didn't want to chance it as they drive their grandchildren around, especially with colder weather around the corner.
American BMW OE is going on 13, made in USA by Exide. This isn’t uncommon with E9x.
I believe so. They were identical other than the labels and color of the casing, which I believe Johnson Controls/Clarios switched to the light gray cases sometime in the last year.same supplier?
