89 Honda filter question
Wisconsin
I don't get this...
The purolator filter crosses with the Super Tech filter, but is a bit shorter. I read around that the purolator has a larger filter that will fit, the 24458, but am a weee bit hesitant to use it because my car (prelude) doesn't appear to have much room down there. From what I understand this is the same suspension as the Civic. Does anyone know if the larger filter will fit? How about the larger filter for the motorcraft filter?
actually, I used this post as a reference. Which one is the typo and which one is correct for the oversized. 14458 or 24458?
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=6;t=001343#000000
[ March 01, 2004, 01:31 AM: Message edited by: Thomas Pyrek ]
24458 is the correct oversized. I have used it on a 94 civic, and it fits. It also fits on a 94 integra. Looking at a 97 accord, there's plenty of room for it to fit there too. But I am not so sure about you year accord.
The AC/Delco 1127 has the most media out of the champion labs filters; supertech, stp, bosch, and I think the 1127 still comes with a spring-type bypass valve.
quote:
Hmm, really? I wonder how close quality control is then...
http://www.overboost.com/story.asp?id=1143
I'll be cutting open all my filters after I try them. STP, FRAM, Powerflow (purolator), ST, AC Delco, Motorcraft, and maybe a few others depending on how cheap I can get them. Basically, I'm using a 3.50 limit on price.
Which ever one I like best I'll get another, use it, cut it open and see how comparative two filters of the same everything are.
If I recall correctly, and some notes I once took suggest so, the Pep Boy's (a big chain in the Southwest) Purolator listings call for #24458 for ALL '88 and '89 U.S. sold Hondas.
is FL-752 the correct cross reference for L24458?
I would like to use the Purolator/Motorcraft, but I'd also like to buy it at walmart.
