Pennzoil Platinum 5w20, 03 Honda, 8k miles
Boston, MA
Pennzoil Platinum SM Synthetic 5w-20
03 Honda Accord EX, manual 5 speed with 2.4L 4 cylinders VTEC DOHC engine.
BlackStone Labs.
Oil had 7,985 miles, 35 weeks, 228 miles/week
Makeup oil: 0.
Car had 50,770 miles, 2 years and 8 months.
Honda recommends 5w-20 oil at 10k miles or 1 year for "normal" driving and at 5k miles or 6 months for "severe" driving for my 4 cylinders engine. My driving is stilled considered "normal" by Honda's definition even with me driving less miles and a few short mileage trips.
VOAs
Pennzoil Dino 5w20 VOA, dated Januarys 2003.
M1 0w20 VOA, dated April 2003.
Pennzoil Synthetic SL 5w20 VOA, dated June 2003.
Pennzoil Platinum 5w20 UOA , dated June 2005.
UOAs
Pennzoil Dino 5w20 UOA with 6.8k miles on oil, dated Oct 2003.
M1 0w20 UOA with 7k miles on oil dated Jan 2004.
M1 0w20 UOA with 7.6k miles on oil dated Apr 2004.
Pennzoil Dino 5w20 UOA with 7.2k miles on oil dated Sep 2004.
Pennzoil SL Synthetic with 6.5k miles on oil dated Apr 2005.
Right numbers are this Pennzoil Platinum 5w20 UOA.
My observations are:
1. Excellent UOA.
2. Wear metals are not much different between my dino and synthetic UOAs.
3. My fuel dilution is increasing.
About two days a week I only drive 2.5 miles twice a day. This must be causing my fuel dilution. Other days I drive a lot longer.
I'm thinking of going back to dino oil and OCI of around 6k miles.
All comments are welcome. Thanks.
VOAs Pennzoil Platinum is different lab.
code:
Syn SL Platinum
Brand: Penn M1 Pennz Pennz
Weight: 5W20 0W20 5w20 5w20
Oil Miles: VOA VOA VOA VOA
Aluminum 1 2 0 1
Chromium 0 0 0 0
Iron 1 2 1 2
Copper 0 0 0 2
Lead 0 0 0 1
Tin 0 0 0 0
Molybdenum 186 67 38 47
Nickel 0 0 0 0
Manganese 0 0 0 9
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium 0 0 0 0
Boron 68 198 0 12
Silicon 3 3 2 3
Sodium 1 7 1 2
Calcium 1856 2892 2149 2301
Magnesium 5 21 18 9
Phosphorus 672 862 728 707
Zinc 785 979 942 772
Barium 0 0 0 0
vis sus@210 52.4 54.9 55.9
Flash point 445 470 430
TBN 7.0 ~12 8.7
UOAs
code:
Syn SL Platinum
Brand: Pennz M1 M1 Pennz Pennz Pennz
Weight: 5W20 0W20 0w20 5w20 5w20 5w20
Unit Miles: 14.5k 21.5k 29.1k 36.3k 42.8k 50.8k
Oil Miles: 6.8k 7k 7.6k 7.2k 6.5k 8k
Oil Weeks: 12 13 14 18.5 32 35
Miles/week: 566 535 542 386 203 228
Day: Oct 11 Jan 9 Apr 16 Aug 23 Apr 4 Dec 5
Year: 2003 2004 2004 2004 2005 2005
Oil Filter: Honda Honda M1-104 M1-104 M1-104 M1-104
Aluminum 9 6 5 5 4 4
Chromium 1 1 1 1 1 1
Iron 14 8 8 5 7 6
Copper 7 3 2 2 1 1
Lead 1 1 0 1 1 0
Tin 0 0 0 0 1 0
Molybdenum 326 89 80 145 65 50
Nickel 0 0 0 0 0 0
Manganese 0 1 0 0 0 0
Silver 0 0 0 0 0 0
Titanium 0 0 0 0 0 0
Potassium 0 0 2 1 0 2
Boron 54 126 125 37 9 10
Silicon 27 13 7 8 6 7
Sodium 4 5 9 5 4 2
Calcium 2088 2939 3074 2255 1922 2477
Magnesium 6 13 14 7 22 13
Phosphorus 818 781 797 748 740 730
Zinc 900 928 946 791 849 891
Barium 2 1 0 0 0 0
vis sus@210 55.6 54.6 56.8 51.5 53.4 54.4
Flash point 400 380 395 370 385 355
TBN 2.8 5.3 6.0 5.5 ? 3.1
Fuel
Antifreeze 0.0 0.0 0.0 0.0 0.0 0.0
Water 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles 0.1 0.3 0.3 0.3 0.2 0.3
Notes:
Air filter was change to a STP SA9564 filter at 28,641 miles,.
TBN of Pennzoil dino VOA may be old method.
Honda oil filters were Honda's USA (Feltell) larger 80mm diameter oil filter, P/N 15400-P0H-305
[ January 10, 2006, 08:08 PM: Message edited by: MikeySoft ]
MikeySoft,
Your post is the absolute neatest post I have seen in some time. It would take me a day or two to get that one right.
Very nice wear numbers. Pennzoil and Honda seem to be a match.
Thanks,
1. The secret is to edit it off line in something like MS Word.
2. Put the report as 'code'.
3. Set the font to 'Courier New' while editing in MS Word.
4. Save your report in MS Word and use it as a starting post for your next report.
Question??
Does anyone know if fuel dilution could go down if driving conductions change?
Example, drive very short trips in New England during the winter, then drive the car to Arizona and drive only long trips.
I don't think I would change a thing. You have almost zero ware and a reasonable long change interval. Continue with pennzoil synthetic and check the fuel dilution. You may have a mechinical problem with that. I would try techron to clean the injection system and do another UOA.
Honda makes great engines. That thing has just finished breaking-in at around 50,000 miles.
Any oil will do well in this engine, but I like the TBN of the M1 better. Nice report.
My last UOA listed .08 for fuel dilution...that was on GC.(2005 Toyota Matrix) I'm in the same situation as you(in NH) where we had that bitter, bitter cold snap in December. I'm hoping that contributed to the fuel dilution...although I do drive 100 miles a day but maybe the long warmup times and short trips on weekends contributed to it.
2005 Matrix UOA on German Castrol
Currently just past 2k on the Chevron 5W30 SL in my engine now. Will probably change out at 3 or 4K and see if my fuel numbers have improved at all.
Nice report!
Goose
quote:
.......That thing has just finished breaking-in at around 50,000 miles.
Help me out here, please. How can it be considered "good" that an engine needs 50k miles before it's broken in?
I thought engines were more efficient (fuel, wear, etc.) when they were "broken in."
Great UOA! Don't change anything!
Wonderful formatting! Are you a professional writer? The logical layout is excellent!
Oh, and by the way, watch out for sludge, you used Pennzoil and ran it for 8K!
I like those numbers, and you're right, dino vs synth doesn't make any difference most of the time in a well-designed engine - which this is. You can see a very nice break-in trend as the wear metals and Si come down, though they weren't even high to begin with.
I'd love to see what Havoline would do, since it almost always seems to lower Fe numbers when run back-to-back with other oils, dino or synth. I bet your wear would be even lower.
Not that it matters. The engine will outlast the car and probably some geological formations as well.
- Glenn
Mikey, Congratulations!!
This is absolutely one of the best oil posts I have every seen!
Not only beautifully planned and executed, but contains more good, hard factual information and data than I can recall ever seeing in one single post.
This is the model for the rest of us to emulate. You have set the benchmark. Thank you very, very much for all the time and effort you put into this post.
I wager that your post marks a significant leap forward in the information garnered from this already superb board.
Thank you!
MikeySoft...h-m-m-m-m, you're really Bill Gates aren't you? I'm surprised with all your money you don't drive the ultra luxury version of the Honda...you know, the Hondabach....
You really did do a great job on the formatting...
WEll done mikeysoft, you deserve a round of 'applause' for your efforts. I really like how you organize everything and set an example for your fellow oil guys in here...
I do have some question for you... how do you warm up your car in that bitter cold area of the country? Do you do alot of WOTs? please explain more of your driving if you can and thanks in advance.
