Can anyone point out the throttle adjustment screw? We got the car running, but it idles at a solid 2500 rpm cold. Once it warms up, it drops to 2000 rpm, but then hunts between 2000 and 2300 rpm.
I replaced the transmission fluid with Redline MT-90. Interestingly, the drain plug is too tight to open for the MT, so I ended up pumping the tranny oil out from the fill hole and pumping in 3 qts, letting it push some of the old oil out as I continued pumping until i used up all 3 qts I bought (fill capacity is ~2.7 qts). I then drove it up and down our long driveway, hitting the brakes frequently to knock some of the rust off of the front rotors. So it drives, but the high idle is weird. Hoping the throttle adjustment screw will help drop it where it needs to be (800 rpm). I just can't figure out where it is. We have a shop manual, but the diagram is not detailed enough for me to pinpoint it. Lots of cracked hoses that will need to be replaced. LOL.
First pic is from the passenger side. Second pic driver side.
