Hi i recently picked up a ford 445 cylinder diesel with the semi auto transmission for the life of me i can not get the starter to engage. Thought the old starter was bad so replaced it but no luck
I've bench tested the starter and it checks out wired it up to the tractor to check for signal from the key and it will engage but once bolted down it will click and not crank it over. I've jacked up the tractor and the flywheel turns when I rotate the tires . Tried by passing the safety neutral switch and same in every gear . Just a strong click and tud. Sounds like the motor is seized but motor moves freely kinda lost on this one
