This comes up all the time at a bike forum for a shaft drive case. The spec is sae90w GL5, but try and find a straight 90?
Guys swear up and down that any other grade won't be as good, so they pay the price for OEM and specialty fluids.
Actually the cold weather properties between the two vary substantially. Without typing out all the specs, a 80W dino gear oil pours at -16°F and a 75W syn pours at -67°F.
There would be no harm using a 75W when 80W is called for, as long as the fluid stays within the range specified for a 90 when 100°C.
For gear oils meeting the same performance specifications:
Benefits of 75W-90: remains liquid in extreme cold and increased fuel economy when operating below 100C (so almost always, unless you do a lot of towing).
Yes I have used one of those and it is SLOW!!
I found one at walmart, it was around 10 dollars, but it looks like it will get the job done in a few mins.
just make sure your diff oil is hot when you try to suck it out. it will come out a lot better.. drive it around for 15 mins or so and when you get back commense to getting the old diff oil out..btw your rear gear box can open. its just sealed shut. you can get the seal stuff at any autoparts place.
