Mobil 1 75w90 vs 80w90 conventional
Washington
I'm going to change the front diff lube in my 2500HD to synthetic. The manual wants 80w90,but I can't find any synthetic 80w90. Will 75w90 hurt anything?
As a matter of fact you will get the added protection from the 75W oil flowing freely in extreme cold compared to 80W conventional.
I have 75W-90 synthetic in the front diff on my 2004 GMC and my 1992 Chevy 4x4. Used it for many years dating back into the 1980's.
What year is the HD? GM had some issues with the RTV sealants in some year trucks and any synthetic which can cause a chemical reation with the RTV. I have the TSB in my notes somwhere and will look for it.
Mike,
My HD is a 2001. The only thing the dealer warned me about, was to change the vent cap to a new synthetic compatable cap. I don't get how the vent cap can be affected by synthtic oil. It seems like he is looking to sell me a $18 cap.
I have a 2003 Dodge 2500, and it evidently has the same American axles (?) as GM. Mine has a 9.25 up front and a 11.5 in the rear. I use Mobil 1 75W-90 up front and 75W-140 in the rear (actually 3 qts 0f the more expensive 75W-140 and topped off with 75W-90). The OEM fluid (a Texaco fluid from what I understand) looked like black snot at 15k miles, while the Mobil 1 looked like darker olive oil at the next 15k mile change. On one of the Dodge diesel forums some have complained about increased noise when trying out Amsoil and no problems with Mobil 1. I like it as readily available, kind of affordable, and seems to be good stuff.
If they are saying that, I think it is just BS. I can't see how a lube can affect noise, they likely had noise to start with and never paid any attention to it but since the changed the lube they have that on their radar screen all the time.
I have used nothing but Amsoil since 1977 and noise it not a problem. Amsoil synthetic gears lubes have been around since the late 1974, I don't recall when Mobil synthetic lubes came out but it was long after Amsoil.
Its a fact of life, some people are going to complain about every darn thing, nothing will please them. I worked with someone for nearly 20 yrs and that guy found fault with everything, and I mean everything.
Amsoil CHRONOLOGY
2005 AMSOIL Foam Air Filter Cleaner
2004 Donaldson Endurance™ Air Filters
2004 Donaldson Endurance™ Oil Filters
2004 AMSOIL Long Life Synthetic 75W-90 Gear Lube
2004 AMSOIL Long Life Synthetic 80W-140 Gear Lube
2004 SEVERE GEAR™ Synthetic Extreme Pressure 75W-140 Lubricant
2004 SEVERE GEAR™ Synthetic Extreme Pressure 75W-90 Lubricant
2004 AMSOIL High Tack Foam Filter Oil
2004 AMSOIL Power Core™ Filters GM H2 Hummer 6.0L Vortec™ and Ford 6.0L Diesel PowerStroke™ Applications
2004 AMS-Oiler™ Oil Precharger
2004 AMSOIL PowerSports Air Filters
2004 Synthetic 5W-40 European Engine Oil
2004 Saber Outboard Synthetic 100:1 Pre-Mix 2-Cycle Oil (ATO)
2004 Saber Professional Synthetic 100:1 Pre-Mix 2-Cycle Oil (ATP)
2004 HP Injector Synthetic 2-Cycle Oil (HPI)
2004 DOMINATOR Synthetic 2-Cycle Racing Oil (TDR)
2004 INTERCEPTOR Synthetic 2-Cycle Oil (AIT)
2003 Torque-Drive™ Synthetic Automatic Transmission Fluid
2003 High Performance Interceptor™ Synthetic 2-Cycle Oil
2003 FLOWZAIR Air Filters
2003 Slip Lock™ Differential Additive
2003 SAE 10W-40 XL Synthetic Motor Oil (XLO)
2002 High Performance SuperDuty Motorcycle Filters
2001 Sirocco® Synthetic Ester Compressor Oil
2001 SAE 0W-40 Formula 4-Stroke Synthetic Motor Oil
2001 SAE 5W-20 XL Synthetic Motor Oil
2001 X-Treme Synthetic Polymer Food Grade Grease
2001 Supershift Racing Transmission Fluid
2001 Shock Therapy Suspension Fluid
2000 AMSOIL/Dahl Fuel/Water Separators
2000 Hastings Premium Filters
2000 Universal Automatic Transmission Fluid
2000 SAE 20W-50 Synthetic High Performance Motorcycle Engine Oil
2000 SAE 10W-40 Synthetic High Performance Motorcycle Engine Oil
2000 SAE 20W-50 Synthetic High Performance Motor Oil
2000 SAE 10W-40 Synthetic High Performance Motor Oil
1999 Thermally Stable Biodegradable Hydraulic Oil
1999 SAE 60 Synthetic Super Heavy Weight Racing Oil
1999 Heavy Duty Metal Protector
1999 Series 2000 Chaincase Oil
1998 Series 2000 2-Cycle Racing Oil
1998 Super Duty Oil Filters
1998 Gasoline Stabilizer
1998 Octane Boost
1998 AW Series Hydraulic Oils
1998 New By-Pass Oil Filter Kits Introduced
1998 Series 2000 Synthetic 75W-140 Gear Lube
1997 The AMSOIL Quick Lube Program Introduced
1997 Series 2000 Synthetic 75W-90 Gear Lube
1997 AMSOIL INC.'s "The First In Synthetics" is trademarked
1997 Synthetic 5th Wheel and Open Gear Compound
1997 SAE 5w30 XL Synthetic Motor Oil
1997 SAE 10w30 XL Synthetic Motor Oil
1997 PI Quick Shot
1997 Pro Formula Car Polish
1996 Series 3000 Synthetic 5w30 Heavy Duty Diesel Oil
1996 Series 2000 0w30 Synthetic Motor Oil
1996 Silicone Lubricant Spray
1995 Series 2000 Racing Grease
1995 Water Resistant Synthetic Grease
1995 Multi-Purpose Synthetic Spray Grease
1995 Series 2000 Synthetic 20W-50 Racing Oil
1994 Non-Pumice Industrial Hand Cleaner
1993 Propylene Glycol Antifreeze and Engine Coolant
1993 Pumice Industrial Hand Cleaner
1992 Cetane Boost Diesel Fuel Additive
1992 Dual Remote By-Pass Filtration System
1991 Biodegradable 2-Cycle Oil
1991 2-Stage Air Filter
1991 5w30 100% Synthetic Motor Oil
1990 BE-100 and BE-110 Spin-On By-Pass Oil Filters
1990 Dual-GARD By-Pass Filter Mount
1989 Synthetic Polymer Food Grade Grease
1987 20W-40 Synthetic Natural Gas Engine Oil
1987 Spin-On By-Pass Oil Filters
1986 80W-90 Gear Lube (GL-4)
1985 Synthetic Multi-Purpose Grease and Synthetic Heavy Duty Grease
1985 2-Cycle Injector Oil
1985 5w30 Para-Synthetic Motor Oil
1984 75W-90 Gear Lube
1984 10w30 Turbo Oil
1984 Marine Gear Lube
1983 Heavy Duty By-Pass Oil Filter
1982 Marine Engine Oil
1982 By-Pass Oil Filter
1982 Home Heating Fuel Extender
1982 Diesel Fuel Modifier
1982 Diesel Fuel Additive Concentrate
1980 Engine and Crankcase Cleaner
1980 Automatic Transmission Fluid
1980 POD Air Filter
1979 15w40 Gas and Diesel Para-Synthetic Oil
1979 SAE 40 Racing Oil
1979 10W-40 Para-Synthetic Motor Oil
1979 Air Filter Foam Oil
1979 Lifetime Air Filter
1978 MP Metal Protector
1978 20W-50 Racing Oil
1978 85W-140 Gear Lube
1978 P.I. Fuel Additive
1976 Grease
1976 Engine Oil Filters
1976 Rotary Compressor Oil
1976 Reciprocating Compressor Oil
1975 Power Foam
1975 Farm Tractor Hydraulic/Transmission Fluid
1975 Hydraulic Oil
1975 SE, CC, CD Diesel Oil
1974 80W-90 Gear Lube
1973 2-Cycle Oil
1972 10W-40 100% Synthetic Oil
From GM Techlink....
quote:
Synthetic Front Axle Lubricant
IMPORTANT: This information is intended for vehicles sold in very cold weather climates, especially those in Alaska and certain regions of Canada.
An upcoming bulletin addresses the use of synthetic front axle lubricant for 4wd C/K trucks with 9.25-inch front axle assemblies sold in cold weather climates.
TIP: Provide a copy of the bulletin to the owner when the lubricant is replaced.
The mineral based fluid used in the front axles of these vehicles may not lubricate properly at -12°F (-24°C) or below. This may contribute to premature pinion bearing wear if a vehicle is driven extensively in very low ambient temperatures.
Before delivery to the first retail customer, the front axle fluid should be drained and refilled with synthetic axle lubricant, following the service manual procedure (document 673354).
It is not necessary to flush the front axle assembly. Use Synthetic Axle Lubricant 12378261 (Canadian 10953455). The approximate fluid capacity is 1.83 qts. (1.73L).
After changing the lubricant, inspect the front axle vent hose connector (fig. 17). The black type is not compatible with synthetic lubricants. If necessary, install vent connector 12479296, following the service manual procedure (document 843184).
TIP: If the vent hose connector assembly is white, it does not need to be changed.
- Thanks to Rich Burrell and Ed Laskowski
quote:
Originally posted by 3000GT VR-4:
Is the M1 OK to use in limited-slip differentials?
From what I've found,M1 is fine for a LSD. On Mobils site,it states that the 75w-90 has a friction additive in the fluid.
Thanks. I should've gone there first . . .
