let me add.. you should remove the tank, fully inspect it for junk inside, if there is any clean it out. if there is a inline filter, remove it and replace it, most of the old fuel in the lines will drain out at this point. If this is a old car with the fuel pump on the block that's one thing, if its newer with the pump in the tank, I would test it to make sure the pump is still functional (turn the key over and listen for the buzz) if the pumps still in working order put a new filter on, 1/4 fill your clean tank and put it back together.. if its a carb motor having a little starting fluid on standby wouldn't hurt.. we need details on the car. I only suggest filling the tank 1/4 the way due to the possibility that you may need to remove the tank again for a pump that lives shortly then dies after a few minutes of operation... I have seen it.
