Here is my 10K sample. It has been in the sump since October of 2021. Fuel is stupid this go around. Likely from the short winter driving I have been doing. However I did do a lot of towing over the summer and fall even into November. When I leave in the morning I put the truck on fast idle for about 5 minutes before I go when it’s very cold. I usually am able to drive it until it reaches 190* EOT but it’s not maintained long there before shutdown. They suggest a lube change, but viscosity is still at 12.9. I would think it would be much less with over 7% fuel. Other than that I don’t really don’t have a problem with the wear metals. The silicon is STILL leaching from the reseal about 12,000 miles ago.
@High Performance Lubricants would you suggest a lube change?
