HPL takes pride in their corrosion test results. I would expect that high amounts of fuel dilution is taken into consideration with their formulations as they have >2 billion miles of fleet data with their oils. Some of those fleets idle for 8-12 hours a day as well. Seeing 8-10% fuel dilution in a used oil analysis is likely not new to them. This used oil analysis is the proof in the pudding since despite having 8% fuel dilution, the KV100 is still in 40 grade range, the wear metals are normal, there's little oxidation increase, and the TBN is on par with what some lesser oils start with. All of this is also at 10,000 miles, where many common off the shelf CK-4 HDMOs would be tapped out even without fuel dilution.
