Thanks to all again. It went into some kind of limp mode as the digital display changed…attached a picture of my digital gauge for example (not my actual just a picture from Internet). My truck just turned over 26,000 miles. It chimed and showed a wrench, then an oil can image, then lastly a thermometer image. No visible codes showed on cluster...will plug my code reader in when I get home and will report back if any codes exist. I turned truck on and pulled out of campsite and noticed this on info cluster…then parked and got out to hook up my tow car (maybe 3-5 minutes) then returned and all was normal. Thought truck was just cold? I reread my 2014 Diesel Supplement and found this below.
Engine protection mode
Ford diesel engines are equipped with
engine protection and emission control
systems. These systems monitor critical
temperatures and pressures, and modify
engine operation accordingly. These
modified engine performance
characteristics are normal.
If these modified engine performance
characteristics persist for an extended
period and either the service engine soon
or powertrain malfunction,reduced power,
electronic throttle control light is
illuminated, have the system checked by
an authorized dealer.
Service engine soon
Powertrain malfunction, reduced
power, electronic throttle control
Never seen this before...it was a cold night as ice was on grass and motor home slide when I left...but not super cold. Appreciate your help as always on here.
