5W40 in Toyota V6 which recommends 5W30?
No Problem!! You will be pleased!! IF you thought that engine was quite and smooth before!!! Just you wait!!!
Any problems with this? SUV is out of warranty and I thought that the Delvac 5W-40 would be a good way to try and prevent sludge build up in this engine which is know to get dirty. Will using a deisel oil or 5W40 oil hurt the engine?
Could this useage of a heavier viscosity oil lead to premature oil pump wear?
With a jump of only one weight grade, I very much doubt it. If he was jumping to a 50 or 60 weight, I would worry about that, but not a 40. If it were me, I'd just listen very carefully for any increased valvetrain noise. If the engine was quieter overall, I would expect it to be fine.
quote:
They are both a 5W, so it would not make one iota of difference.
A heavier viscosity oil would be a 15W-40 or a 20W-50. If they are both 5W-xx, they are both thin oils. IMHO.
Dave
