I've never had a much truck but have had pickup trucks that take 5W30 and have used up to 5W50 with no issues.If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems ?
I think he meant Mulch Truck would that change your recommendation?I've never had a much truck but have had pickup trucks that take 5W30 and have used up to 5W50 with no issues.
You mean those that blow out mulch like,I think he meant Mulch Truck would that change your recommendation?
Hey! You're really getting busy on that truck! What year, model and engine do you have? You bought this used right? How many miles on it when you purchased it?If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems ?
Suppose you know the oil PSI at a given RPM while at operating temperature when it was new. Personally thinking higher viscosity would bring the PSI up now. Maybe 5w40 would do that but those are two unknowns.If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems ?
It'll be fineI have a 2008 Nissan titan. The main reason in asking this question is I can buy 6 quarts of brand new Royal Purple 5w40 for only $10
Should be OK to go up one grade no problem IMO. Especially if the manual mentions it OK.I have a 2008 Nissan titan. The main reason in asking this question is I can buy 6 quarts of brand new Royal Purple 5w40 for only $10
It would be just fine.If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems ?
On my next oil change in the Crown Vic, I'll be switching my grade from MC 5w-20, to Mobil 1 5w-40.If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems
$10 per qt, or $10 for all 6 qts?I have a 2008 Nissan titan. The main reason in asking this question is I can buy 6 quarts of brand new Royal Purple 5w40 for only $10
