5w30 - VS - 5w40?
DR1
Florida
If much truck with 147k miles on it calls for 5w30 from the factory is it ok if I use 5w40? Any problems ?
Florida
If it's gone 147K miles with 5w30, why change? The 5 is the same. The 40 is higher viscosity at operating temps, compared to 30. The engine was designed for 5w30. If the owner's manual gives 5w40 as an option, then do it, otherwise, use what the manual says.
ZeeOSix
$100 site donor 2022
PNW
Is it burning some oil and that's why you want to go with 5W-40?
  • Like
Reactions: FZ1
Suburban Washington DC
I think he meant Mulch Truck would that change your recommendation?
You mean those that blow out mulch like,
Yes if that's a commercial diesel engine, but he made no mention of that.
The Midwest
Why not a 10W30 synthetic being your in Florida? Some of the cheap synthetic 10W30's have shown an impressive NOACK.
Upstate NY
Hey! You're really getting busy on that truck! What year, model and engine do you have? You bought this used right? How many miles on it when you purchased it?
So Cal
Suppose you know the oil PSI at a given RPM while at operating temperature when it was new. Personally thinking higher viscosity would bring the PSI up now. Maybe 5w40 would do that but those are two unknowns.
So Cal
I have a 2008 Nissan titan. The main reason in asking this question is I can buy 6 quarts of brand new Royal Purple 5w40 for only $10
Should be OK to go up one grade no problem IMO. Especially if the manual mentions it OK.
