- Joined
- Sep 28, 2002
- Messages
- 39,799
Originally Posted By: BuickGN
Originally Posted By: Gary Allan
It's going to be hard for a high output motorhead from thinking in any other terms than thicker is better. It would be the same with higher output Euro-alloy types.
Just like it's hard for a new construction home buyer not spec'ing a bigger air handler and higher tonnage compressor even though it may produce unfavorable side effects and undue expense.
No one wants to think of 1/2" drywall as being a 1/2 hour fire wall (or whatever it is). They want concrete block.
It's all about margins. People integrate that the bigger the margin ..even if it will never be challenged at the lower/smaller/shorter level ..into "better".
There's no real logic to it. It's like saying you'll live longer if your 3000 miles from a cliff vs 20 feet. This may be true if you're someone who wildly break dances as a routine activity.
I'd recommend that our next safety evolution in automobiles be the installation of titanium roof panels to offer greater protection from stray meteorite hits on the occupants.
It's not just about margins. Look at GM's test using the 3.8L with a low HTHS oil and a higher HTHS oil. Rod and main bearing wear was cut by 5 times with the higher HTHS.
..but suppose that 5X was totally insignificant in shortening the life of the engine from 350k potential miles ..and what were the conditions of the test?
That's the problem with those types of statistical analysis.
We can surely reason that there were millions of 3.8 engines that were ASSAULTED by their owners ..neglected ..abused.. thrashed ..all on low HTHS fluids ..and most survived long enough to be driven to the junkyard.
Now how much fuel was needlessly consumed over that same span just reaching operating visc ..especially when most were operated 20 minutes or less?
