God help those circuits… such fragility.And the circuits![]()
Newer Toyota's that specify 0W-16 have an electric oil pump designed to maintain lubrication with a low viscosity oil as stated in a BITOG post.Toyota has calibrated oil pumps - don’t do it!
No they do not.Newer Toyota's that specify 0W-16 have an electric oil pump designed to maintain lubrication with a low viscosity oil as stated in a BITOG post.
Apparently, I should have verified what I found in a BITOG post. Well then, do the engines that specify 0W-16 have pressure control valves operated via ECM?No they do not.
https://www.shell-livedocs.com/data/published/en-US/126583ca-eb28-4530-8bd6-067e647a43af.pdfApparently, I should have verified what I found in a BITOG post. Well then, do the engines that specify 0W-16 have pressure control valves operated via ECM?
Would you be kind enough to provide a link to that post?Newer Toyota's that specify 0W-16 have an electric oil pump designed to maintain lubrication with a low viscosity oil as stated in a BITOG post.
Great to hear … I wanted to make sure no reduced oil galley size holes , VVT issues with a thicker oil , etc. that may require staying with 0W20 . My other vehicles use 5W 30 SP D1 / Gen 3 so looking to standardize on oil .5w30 is fine. Other country's manuals even allow for 20w50 for that engine. I have a '22 Corolla with the same engine and have used 5w30 since it's first oil change.
https://bobistheoilguy.com/forums/threads/toyotas-new-electric-oil-pump.355614/ I only read the first 5 replies, not the entire 10 pages.Would you be kind enough to provide a link to that post?
Assuming they did check it, could they even tell? There are plenty of UOA’s out there which show the oil slipping below grade after some use due to various factors outside of the owners control.If there was an internal engine related problem, they will ask for oil change records at the minimum. If it shows you didn't use the recommended oil and they want to be hard nosed about it, I can see them denying warranty coverage.
Stupid Question : Do the majority of Toyota Dealers use Toyota Genuine Motor Oil for serving their vehicles ? Toyota has a reputation for having a very good quality synthetic oil .I have 5W-30 in a 2011 Toyota 4Runner Trail even though the manual specifies 0W-20. My 2023 4Runner will have 0W-20 genuine Toyota motor oil during the warranty period and then switch over to 5W-30. The way I see it, 0W-20 is at the very bottom end of the allowable worldwide viscosity range and both vehicles are subject to short trip city driving which qualifies as severe service. I'd rather have the extra margin of protection that a high quality 5W-30 offers for the summer heat in Phoenix. I change oil every 5000 miles instead of the recommended 10,000.
When I had my old Corolla, I know that my dealership if you didn't request the Toyota Genuine Motor oil you would get Chevron!Stupid Question : Do the majority of Toyota Dealers use Toyota Genuine Motor Oil for serving their vehicles ? Toyota has a reputation for having a very good quality synthetic oil .
It says, if not 0W20 then 5W20. If you want to give Toyota an easy excuse to deny an engine warranty claim, not using the oil recommended is near the top of the list just below not changing it enough. Go all the way and use 5W50. I put that in a truck that takes 5W30 but it has over 200,000 miles.The manual states 0w20 is the "best choice" not the ONLY choice. Big difference.
The consensus is varied. Some who have worked for dealerships say they use whatever is the cheapest in bulk, and others have said they use only the manufacturer’s brand of oil… only way to know is to ask your dealer.Stupid Question : Do the majority of Toyota Dealers use Toyota Genuine Motor Oil for serving their vehicles ? Toyota has a reputation for having a very good quality synthetic oil .
Keep reading.https://bobistheoilguy.com/forums/threads/toyotas-new-electric-oil-pump.355614/ I only read the first 5 replies, not the entire 10 pages.
https://bobistheoilguy.com/forums/t...rce-four-cylinder-electronic-oil-pump.363945/ thread is 3 pages long, 6 months more recent and contains a link to https://global.toyota/en/powertrain/engine/ that includes a description of the continuously variable capacity oil pump.Keep reading.
It positive displacement pump. It can handle higher and lower viscosity fluids and can operate at high pressures and relatively low flows efficiently. The ECU is able to control pressure and flow as needed based on the needs of the engine.https://bobistheoilguy.com/forums/t...rce-four-cylinder-electronic-oil-pump.363945/ thread is 3 pages long, 6 months more recent and contains a link to https://global.toyota/en/powertrain/engine/ that includes a description of the continuously variable capacity oil pump.
You’re claiming you can use an uncontrolled $30 spectrographic analysis to determine which winter rating produces less wear?The only reason to avoid 5w30 would be in places where cold starts are below about -10F. Maybe a bit higher if you are one of those “first 3 seconds” wear people. But even then a 0w30 would be fine. Ideally, do a run of 0w20, then a run of 0/5w30 and see which UOA is better.
