MolaKule
Staff member
Gopher,
Are you referring to a specific viscosity spec or to a quality/test spec?
Molakule, the interesting thing is that both my 02 Explorer and the 2000 Mazda B3000(Ford Ranger) that I traded for the Explorer both only said to use an API SJ certified 5W30 oil. Unfortunately, there was no temp range in the manual, or I would use 10W30. I had mentioned in another post that I have been trying to find Chevron Supreme 5W30, but the slot for it at Walmart is always out, they usaully only have 10W30 or 10W40. So twice now I end up buying the 5 Qt. container of Castrol GTX. -Joequote:
Originally posted by MolaKule:
Joee12,
Take a look at the user's manual see if has a oil viscosity (weight) chart versus temperature.
The 5W30 is a minimal oil, and if you are pulling anything, I would use no less than a 10W30, specifically in full synthetic.
And change the tranny and differential fluids as per the severe service schedule. Most differential shops recommend a differential oil change every 12,500 miles if you pull anything.
Here is the series of posts on F150online:quote:
MNgopher,
Does the 5.4L V8 have an integral oil cooler in the radiator?
Is this a thermocouple type heat gage or a factory heat guage?
My '92 Burb's 5.7L oil runs at 180 F in 100 F weather unless I'm pulling a load.
