Originally Posted By: BuickGN
Originally Posted By: rg200amp
Yes, you can use a 0w20 anywhere a 5w20 is spec'd.
The 20 is the weight at operating temp.
Do you know that for sure? It's not good to recommend stuff when you're not sure.
My guess is a comprable 5w-20 may have a higher HTHS.
From Mobil 1's Website:
Mobil 1 0W-20 Advanced Fuel Economy outperforms conventional oils and meets or exceeds warranty requirements for many Ford, Honda, Toyota, Mazda, Mitsubishi and Chrysler vehicles. Mobil 1 0W-20 Advanced Fuel Economy
is recommended for SAE 0W-20 and 5W-20 applications, and is suitable for the following:
ILSAC GF-4 energy conserving
API SM/CF
Chrysler MS-6395
Ford WSS-M2C930-A
It rounds out a lineup of Mobil 1 products that are engineered to help keep your engine running like new. Mobil 1 0W-20 Advanced Fuel Economy exceeds the industry's toughest standards in its class and outperforms all conventional oils. It offers exceptional performance under all operating conditions, pours at temperatures as low as -53°F (-47°C) and protects at oil temperatures as high as 400°F (205°C).
It is specifically designed for applications requiring an SAE 5W-20 oil such as most Fords, Hondas and 2005 Chryslers.
From Amsoil's Website:AMSOIL Synthetic 0W-20 Motor Oil is recommended for Honda, Acura, DaimlerChrysler, Toyota, Ford and all other applications
where SAE 0W-20 or 5W-20 is required with the following specifications:
API SM/CF, SL, SJ. . .
ILSAC GF-4, 3. . .
ACEA A1/B1
Ford WSS-M2C930-A
DaimlerChrysler MS-6395N
Yep I am sure
