OVERKILL
$100 Site Donor 2021
As you all know, the last oil change in my parents Expedition (not mine) was a switch from Mobil 1 5w30 to Mobil 1 5w20. This vehicle and engine were back-spec'd to 5w20 so this shouldn't have been an issue.
But it apparently was.
Dad changed the oil out probably 6 months ago. Mobil 1 5w20, K&N filter. The vehicle has since then hauled two U-haul trailers a distance of 1,528Km each, the most recent being two weeks ago.
Dad fired up the truck the other day, it is the first time I've heard it run since the switch to 5w20. Sounded like it had bloody rod knock!
I know it is NOT rod knock though, as the engine began to get a little quieter as it ran.
This engine has NEVER made noise. It has never had piston slap or timing chain noise. This is NEW.
Dad was understandably concerned as well, as he had noticed this happening since their last big tow.
Oil had about 7,000Km on it.
So, we took the opportunity to "step it up a notch" on the oil grade.
Dumped the 5w20, which looked absolutely disgusting, and filled with Mobil 1 0w40 and a Fleetguard Stratapore filter.
Started it up, noise was MUCH less pronounced and continued to get quieter and quieter until after about 2 minutes, it was almost completely gone. Took it for a nice long run and when we returned the noise was no longer audible.
Dad does not know a lot about oil. He doesn't want to. But during our trip, he turned to me and stated that the engine was a LOT quieter now, and he was surprised. Considering I had made NO mention about how the engine itself sounded (other than the obvious noise we were trying to get rid of, which was ONLY audible from OUTSIDE the vehicle), this kind of surprised me.
I have the filter from the truck and will cut it open and post pics later tonight.
I have a good sized sample of the oil from the truck and will be sending it off to TOROMONT CAT to be analyzed like the Mobil 1 Turbo Diesel Truck from my truck was.
Dad is now asking about using this oil in his Lincoln... The quieting factor seems to have had an effect on him......
