5w-40 recommendation for 392 HEMI
Originally Posted By: A_Harman
For Chrysler's 6.4 Hemi:
470 hp / 392 cubic inches = 1.20 hp/cid
For Chevy's 7.0 LS7:
505 hp / 427 cubic inches = 1.18 hp/cid
Come on Chrysler, do whatever you need to do to bore and stroke the Hemi to 426!
Numbers do not tell the tale here. Peak hp is better, but at low rpm that Hemi is making WAY more torque than the LS7.
That's what makes this thing a monster on the street. No waiting for it to wind up, it's always there.
Went to Advanced Auto Parts and they had Castrol Edge with SPT 5w40 on sale so I picked up enough for two oil changes. After rebates it comes out to about $5.80 per quart. Any reason not to go with the Castrol? I don't beat the living pi$$ out of the car on a daily basis but do like to get on it full throttle a couple times a day.
I agree, though need to mention:
For Ford's 5.0L BOSS 302:
444HP / 302 cubic inches = 1.47HP/cid
It's a 4-valve engine, that's cheating.
This is what Merk recommends right here :
Why would you want to use this mid-SAPs, weak add pack, weak TBN oil if you can have Mobil 1 0w-40 for about the same price?
It'll be fine.
ZIIIIIIIIIING!
your hp/cuin comparisons don't tell the real story, which is pounds (of car weight) per hp.
You want to talk MONSTER---> the 505 hp Corvette is only pushing around 3150 pounds-at all rpm ranges. Drive one and you'll get out of the car and kiss the ground. A slight, OK 3/4 throttle, acceleration in first gear at 25 mph was enough to give my son hiccups for about 6 hours
I believe that Synpower 5W-40 is superior to Mobil 1 0W-40.
Can you elaborate? I'm curious what I'm missing.
Ford's Boss Engine needs to spin to 7400rpm to get that 444HP (7500rpm redline)> Not saying that is a bad thing just pointing out it is a high revving track car. It has no more torque, and actually has a little less torque than the regular 302 Coyote in the Mustang GTs and it comes on 250rpm later than the regular engine which tells me it may have less torque down low compared to the GT Engine. Now the fun part is it is a fully forged rotating assembly so drop a twin-screw on top of it and OMG!!! But at an 11:1 compression ratio I would think boost would be somewhat limited on pump gas, but I haven't been following what folks are doing on the new 302 as the GT version is 11:1 also and guys are boosting those already.
The 393 HEMI is all about torque, over 400lb/ft from 2500-6000rpm peaking at 470@4250rpm and it needs top as the car is massive/beasty. If one wanted to, you could drop a CAI in the car and some upgraded valvle spring and once the car could be tuned up the rev limiter to 7000rpm and the 392 would pump out 500+ bhp no problem.
The LS7 in the Z06 is very comparable in torque curve to the 392 albiet with more displacement and a higher compression ration of 11:1 to the 392 10.3:1. It gets to 400lb/ft by about 2500rpm and doesn't fall below 400 until 7000rpm at least on the GM Performance Parts page that shows the engine dyno and actually winds the engine to 8000rpm. It does the same peak torque as the 392 with 470lb/ft but it comes later at about 5100 but holds that flat until 6100rpm before falling off.
I'd be happy to have any of the engines under the hood and what Ford has done with only 5 liters is very impressive, it really speaks to the efficiency of the design. It trumps the 392 and the LS7 in both hp/ci and tq/ci at peak but I want my torque down low and need it with the weight of this car.
In the curb weight/HP game the Z06 is the monster by a long shot while the 392 and the Boss trade 2nd and 3rd place depending upon wt/hp or wt/tq
Z06 6.3:1 wt/hp (3199lbs/505hp 6.8:1 wt/tq (3199lbs/470lbft)
Boss 302 8.2:1 wt/hp (3632lbs/444hp) 9.6:1 wt/tq (3632lbs/380lbft)
SRT8 392 9.1:1 wt/hp (4257lbs/470hp) 9.1:1 wt/tq (4257lbs/470lbft)
Why did I type all this, not sure, I was bored and it was interesting to look at the dynos and weights. I'd be happy to have any of these cars in my garage but right now with four young kids, the Challenger is the only one that can haul them all at the same time, with the wife following behind in the minivan of course.
As an aside, the Advanced Auto Parts Castrol sale included two Fram Extra Guard 3x filters, I normally use the PurOne filters on all the cars and was wondering if the Frams were [censored] or ok to use for 5000miles each.
theta II 2.0T 122 CI 274 hp : 2.25 hp/cid lol
That's a turbocharged 4 vpc engine. We're talking about naturally aspirated 2vpc engines with about 500hp. Try again if you want to make a relevant contribution to the discussion.
Is this why most high revving-high performance engines always recommend thicker oils (40,50 weights) and warn against using thinner weights when racing/driving extended high speeds?
In what alternate universe?
People "believe" in all sorts of things... ghosts, tooth fairies, Big Foot...
Originally Posted By: artificialist
What I don't understand is why the Hemi doesn't produce a significantly higher HP/L even though Chrysler went through the trouble to build a hemi style head, whereas the Chevy has a much simpler wedge head.
FWIW, "Hemi" has been just a marketing term for years. Hemisperical combuston chambers have problems meeting emmission limits and have been pretty much phased out since the '70's.
Yes, Chrysler's small-block Hemi isn't a true hemi, but neither was the 426 or the 392 (331, 354, 392) family that preceded it. None of them had combustion chambers that were half of a sphere. The big advantage of a Hemi is the ability to put large valves in it, thereby enhancing high-speed breathing ability. The dual spark plug, twin squish combustion chamber of a new Hemi gives a lot faster burn than old single-plug quiescent chambers.
I would think most people know that Hemi is just a marketing term.
Regardless, look up the flow numbers on those new heads. They're pretty impressive for ole 2 valvers.
