I think slomo is repeating the common layman explanation from many decades ago when multigrades became popular.Based on your statement, an oil will thicken when hot. This is simply not true.
"This product "acts" like a 5W at and below freezing but has the needed viscosity of a 30 grade when at operating temperature."
I think the hitch is in "acts like" a 5W. Various 5W-Xx do not evidence a similar viscosity at 0C - they can easily be 100's of cSt apart.
The Winter grade rating relates primarily to the max allowable cP thresholds for pumping and cranking and also apply more to cold gelling and wax formation than the viscometrics at temperatures around and above zero C.
The old solvent refined product required heavily on the use of dewaxing and a very light constituent base to "act" like a 5W when cold. Then a high percentage application of VM to maintain the target viscosity and HTHS when hot. These VM were low quality and likely the primary reason for heavy varnishing and gummed and stuck rings through the 60's and 70's (along with marginal oxidative stability). These products were also highly susceptible to degradation and loss of "in-grade" performance.
Unfortunately old and incorrect explanations are everywhere and even an A.I. co pilot might just pick and quote from one of them
-Arco
