Put 5W-20 in 5W-30 Mower
Question, in 5W-30 oil, the 5 is the cold viscosity, and 30 for hot, right? So surely in this case 5W-30 and 10W-30 are the same?
No and No. The 30 is the Grade which relates to a viscosity range at 100 deg C. The W number is a test range for pumpability at temps far below freezing.
5W mutigrades tend to be made from low viscosity base stock blends, 10W somewhat higher viscosity basestock.
The higher viscosity base oil in mono grades and big W number multi's provide a better working "film strength" but only in concert with quality EP and AW additives.
True iv and v group synthetic oil can break some of the above rules-of-thumb as they can avoid gelling at cold temps and provide pumpability and meet low W numbers with a higher ISO basestock
Air cooled engines have zero temperature regulation. They often run cool under low load conditions and excessively hot when heavily loaded. The 20 viscosity oil and it's HTHS of 2.7 will be fine when oil temps don't climb. But it is generally accepted that for full protection under harsh conditions, when oil temp climbs into the mid 200's, an HTHS of 3.8 is necessary.
Honda generally does a great job designing their engines not to overheat the oil, the secret to long life. Even so, if conditions are harsh, a robust oil is best.
Lots of steps skipped there though, that assumes I have the mower and all the supplies out ready to go. I don't have any more oil changes to do for a while, and I don't have any waste oil ready to go out
So, I'd have to dirty up my "clean" oil drain pan or oil sucker doo-dad, and funnel. I'd also have to then have some waste oil sitting there ready to go out, and then clean everything again when I'm done, and accidentally drop some on the garage floor (Required step)
Figured I'd check here first, no point in changing it out if its not even required
I may just leave it in there, I really doubt its going to make much of a difference. Just don't reference this post when I show off a new mower in another thread :ROFLMAO:
I would just leave it alone for this OCI.
But I have a suggestion for future oil changes for the Honda (to reduce the hassle)...instead of digging out a drain pan, just go to the local 7-11 and get a large cup of soda. After you finish the soda and dump the ice, just remove the fill cap/dipstick and set it aside, hold the cup under the spout, and tilt the mower to the side to pour the oil into the cup; sometimes it is helpful to put your foot against the tire to keep it from sliding as you tip it with one hand. It only takes about 14 ounces of oil so the cup will not overflow. The drink cup even comes with a lid...
That's a little bit of a nuanced answer for a basic question about OIL FOR A LAWNMOWER. In this application, I think we can assert the equivalency of 0W30 and 5W30.
I'm going to pull the 5W-20 out and mix the rest of the 5W-20 with this 15W-40 I just bought and throw it back in
Just use that oil for one interval. It is a very good lubricant and the motor will tolerate it without question. Folks need to be reasonable and listen to the question that you are asking. The problem is that you are brushing up against the thick v. Thin eternal debate on BITOG. If your mistake had gone the other way, and you had filled the motor with Mobil 1 0w40, nobody would be suggesting that you change it out.
Of course not since that is a 40-grade oil. Physics matters, an oil of a higher HT/HS won’t damage the engine but one with too low most certainly can.
Or maybe there is not even one lawnmower on the face of the earth that has been damaged by a slightly thinner oil. Possibilities and probabilities are very different things.
Yes but too low of a MOFT is exactly how you create wear. For what reason should I or anyone risk that happening? Just to get 100 square feet extra of cutting per tank? There's no downside. I also use a Euro approved oil for the other benefits such as proven deposit resistance.
My Toro aluminum deck lawn mower was built in the early 90s and is still going strong, perhaps that influences my choice.
