Quote:
I have an issue with someone putting TES295 in hydraulic system that is suppose to have 5606. What I need to know are they compatible. If they are I think I would just need to flush the system and put in 5606. Everyone else says no we have to replace all the components in the system. Any info would be greatly appreciated. Thanks
For future reference, the TES295 is a synthetic ATF speced for the commercial Allison transmissions, with a viscosity of about 7.5 cSt, whereas the 5606 has a viscosity of of 5.1 cSt. This 5606 fluid was developed for MIL equipment in which the operation was to be in low temp situations.
A maintenance supervisor should be aware that the Royco 756 is a hydraulic fluid replacement for any MIL-PRF-5606 spec fluid.
I doubt there was any damage done, but I would check seals and hydraulic controls. Sounds like someone needed a commercially available fluid when the MIL spec stuff may not have been available.
