5-20,5-30 or blend
ariz
I have faithfully been using 5-20 MC blend in my 06 F150 3V
for 5 years and changed oil every 5,000 mi. The truck is used only 6,000 mi a year,2000 of which it tows a 4,000 lb,19 ft trailer.I have always been concerned the 5-20 was to light for the hot summers.Now that its out of warranty,I would like to go to 5-30 Full Synthetic and change once a year.I have thought about blending 5qts 5-20 blend with 2 quarts Pennzoil Platinum 5w30 blend to increase amount of syn and make the 5-20 thicker. I plan on keeping the truck 4 or5 more yrs.Yes,I'm retired and have to much time on my hands.
Thanx
With those miles I dont see a big advantage of going to full syn. Id stick with the MC blend and change once a year if only 6k. The recent msds for motorcraft shows the SN is 60% synthetic. 5w30 might hold up a bit better due to the hot conditions and towing but I doubt your 5.4L would know the difference.
I don't like mixing across brands, as a general rule. And if you want to go to a 30-weight, just do it and don't take half-steps by mixing 2 quarts 30 with 5 quarts 20. 20-weight viscosities all cluster in the upper third of the range anyway, and most 30-weights are in the lower half of their range.
Is there a 5w30 MC blend that you can buy off the shelf? The MC blend is well-liked on this board. Or 5w30 full synthetics made by Conoco-Phillips will have about the same additive package as the MC oils.
There are used oil analysis that show higher wear numbers on those V8 Ford trucks when xw-20 is used. Since you're in Arizona, I would stick with a 10w30 (PP or Motorcraft should fit the bill) and not look back.
Go all 5-30 or 10-30. Synthetic or otherwise probably won't matter. Since it's 4 dollars once a year and you're towing in AZ synthetic would be the choice for me.
You get another vote to go ahead and just change to 5w30. Don't mess with mixing them. You can mix oils and I do myself sometimes, in this case a 5w30 (syn or not) would be fine to switch over to. I would go with PP, PU, or M1. PU would be a good start though to clean a little extra if it needs it.
Sticking with the MC 5w20 sure won't cause any problems.
Really? I have not seen any higher wear numbers in my used oil analysis using 5w-20 and I pull some heavy loads while running it.
Here are 6 of mine:
Here are 6 of mine:
Yes, really.
2002 F-150 4.6L
Not much needs to be explained about this UOA. Iron numbers are high.
2007 E-350 5.4L
Iron is at a reasonable level on this report, but copper is borderline high. TBN is also starting to get low, but that probably does not indicate engine wear.
2005 Mustang 4.6L
I posted this one just for giggles. It's not a Ford truck but it's powered by a mod motor, and at 35k it should be past its break in period. Iron is getting high and copper is astronomical.
I could spend some time searching and come up with at least 3 more that show the same trend, just as I could dig up xw-20 used oil analysis that show lower wear numbers. This is just my observation.
I'm for creating your own 'Blend'.....and am thinking about doing it myself when my vehicle reaches 130K or so.
Since Pennzoil conventional might be considered on of the better conventionals....and PP is a highly touted synthetic (by many here on BITOG).....I would use these two in a blend.
A good Blend... IMO might be.... 4 quarts of of Pennzoil conventional....and 3 quarts of PP.....should make a real stout Blend.... and you would be mixing oils of the same company (SOPUS).
IMO...5w30 would be OK....and a 6K +/- or 1 year OCI.
You didn't mentioned the filter you use. I would suggest a Purolator PureOne or Bosch Preminum....which would be perfect for the above 6k OCI.
Here are 6 of mine:
Yes, really.
2002 F-150 4.6L
2007 E-350 5.4L
2005 Mustang 4.6L
And this proves what? Those are specific engines. used oil analysis dont show wear, they establish trends for extending oci. Unless you have teardown specs of engines we do not know that xxw20 causes more wear on a ford v8.
Thanks for the replys.You have convinced me.One more oil change in my driveway to use up my oil I have on hand.5 qt 5-20 and 2 qt Pennzoil Platinum 0w30 synthetic. and my last MC 820s filter.Next year its to the dealer for oil change and antifreeze change.At only 40,000 mi or so,but going on 7 yrs, should I have the transmission fluid changed?
Thanx again
It's not likely necessary to thicken up the 20wt oil you're running, but I also don't have a problem with the blend you're suggesting which will give you a mid-grade 5W-20.
Or why not just switch to a mid-grade 20wt like Mobil 1 0W-20 (HTHSV 2.7cP) which meets the Corvette 4718M spec' or the even heavier Mobil 1 5W-20 (HTHSV 2.75cP).
With your logic, 2010_FX4's UOA sheet is also meaningless in this debate then.
Right; just as mine show low numbers. It all depends on the engine and how it is used/maintained. I would not switch my 5.4L over to 5w30, because I see nothing gained by doing so. It is not fair to say that 5w-20 causes more wear anymore than it is fair to say that 5w30 causes less wear. It just depends...
The 5w30 will cause you to have massive amounts of cold start-up wear; especially
during the summer. You better stick with 5W-20 for the quick flow at start-up.
Thanx
The blend option sounds much better to me. 2 out of 7 qts of 5w30 should thicken that 20w oil up a good bit. Plus, with any make up oil you add as 5w30 you'll make up for most of any loss of viscosity from the miles you put on.
In AZ I'd have had 5w30 in from day one, no check that, if towing it would get 0W-40 M1...
