I was driving to work in the snow this morning, and started thinking about the 4WD system in my truck. Are they all the same when it comes to winter driving? Are some systems "better" than others? Not talking about advanced AWD systems, just regular 4WD systems in pick up trucks.
All new pick trucks have some sort of "smart" system that effect off road driving. To the experienced driver off road, they are very annoying, and do not allow the full capability of the vehicle.
New GM trucks for instance, if you are driving off road, and get "to far" out of level, stabilitrack will engage, which is really more a function of the ABS......anyway.......you are going up a hill, slightly sideways, and all opon a sudden you lose all power. Not safe. You have to put the truck in 4LO, to "disable" stabilitrak.....Hard to rooster tail much in a heavy truck in 4LO, to slide the rear end around a curve if need be.
Also, speed somethimes is needed offroad, or more specifically, momentum. Again hard to do in 4LO
My 2015 3500, with "manual" shift does as above.
Older systems are fully mechanical, typically robust, and last forever. I currently have all of the common systems in 4wd trucks......that I know of.
full manual with manual hubs
full manual with axles sleeves as the "hubs"
partial manual with electronic front actuator and stabilitrak
4wd with 4wd auto, 2hi, 4lo, with stabilitrak
The best IMO is full manual, full mechanical, but they have not made those for quite some time.
