That's what I get for going off memory alone......I was wrong Not to worry because I write down everything!!!
*You can run a '04 & up pump in a '97-'03 Case without issue.
*You can run a '97-'03 pump in a '04 & up Case IF you plug the Cooler Return hole. The '04 & up case doesn't have the boss to block the cooler return (Which was left over from '90-'96 models)
The boss in the case that was eliminated in 2004.....
