Have an 80 that i built about 3000 miles ago with the straight cut gears on the output planet. From day one I have a gear sounding whine when in park or neutral which sounds exactly like the typical 1st gear planetary whine while driving but a much quieter . Noise goes away in R or any fwd gear ( stationary), unit shifts fine, in dash pressure gauge and pressures are normal and steady, never seen over 190 degrees. everything operates normal and quiet.
When I blip the throttle the whine does like what a ford powerstroke turbo sounds like it when you burp the throttle - a lazy spool up and the lazy spooling down in relation to the engine rpm. I don't " think" I have any issue but just curious about the "why"
I know power flow terminates at the fwd clutch housing in P and N but is there any way with parasitic drag on the apply components could the fwd clutch/direct clutch hub/ clutch assy be turning the sun gear shaft which would drive the output gears on the pinions causing the whine? Or thru the fwd clutch hub driving the input shaft and the rear internal gear driving the pinions going that route?
