I have a 09 Sierra with the 4l60e about 50,000 km ago i changed the filter and bled the system with mobil dexron vi. since then about every 20,000km ive been using a fluid vac pump to remove what's in the pan and top off with the same fluid.
I think my truck falls under the severe use category and i installed a pretty big aftermarket cooler.
just wondering how often i should actually pull the pan off to clean it up and install a new filter?
