A BIG BANG does not fire multiple cylinders at the same time. they are separate events.
Sometimes ... "Big Bang" Engines
Never. They never fire multiple cylinders simultaneously.
In the article it said:
"The Honda NSR500 began and ended its life as a screamer. However in 1990 Honda connected both of the pistons in one bank to the same crankpin and both of the other pistons to a crankpin offset 180°. This NSR500 was called a 'big bang'."
In that V4 engine, two of the four pistons fired at the same time. It was essentially like a big V-twin in terms of power pulses from the pistons firing (two at the same time in the same bank).
You do realize that the NSR 500 was a 2 cycle engine right. So has absolutely no bearing on this discussion.
And for the record I work in a Machine Shop. I see more disassembled engines in a month than most gearheads will see in a lifetime. not kidding.
