Stellantis Hurricane4 Engine Reveal
Pennsylvania
The Drive Article
Looks like it is quite an interesting engine. I'm thinking I will be in the market for a 3-Row vehicle pretty soon so I'm interested to see how it performs in the Grand Cherokee L.
Max Horsepower: 324
Max Torque: 332ft-lbs
Estimate Grand Cherokee MPG: 21/23/27
Some listed Features
- Variable Geometry Turbo
- Turbulent Jet Injection in addition to 1 regular spark plug in the combustion chamber.
- Port and Direct fuel inject
- Electric water pump
- Block design appears to be an open deck design. But with the thickness of the cylinder walls it is probably closer to a closed deck than an open deck block.
Power density is 26% higher than the Hellcat Redeye V8 at 126hp/L.
Specs on paper are great… let’s check back in 10 years :)
I've seen them as auxiliary and that's okay for once the vehicle shuts down.
I think those are auxiliary to keep the turbo cool correct?
For actual primary cooling pump, Prius has had electric water pump since day 1. Camry since 2018. Rav4 since 2019. The one on my Rav4 even looks very easy to replace, which is a bonus if it ever needs to be.
I don't understand why there is a spark plug in the main chamber too if the spark plug in the pre chamber ignites that fuel-air mixture which jets into the main chamber to ignite that main mixture.
I would imagine it just helps with combustion stability and NVH at idle and low-med loads. It looks like they only use the pre-combustion chamber spark plug at high loads.
