4.73 L vs 5 L oils
Canada
I noticed some oils come in 4.73 L (5 quart) jugs and some in 5 L jugs.
I assume this is because oils blended in Canada and Europe will use metric?
Is this a factor when you are buying oil? If it is the same price, you will get 0.27 L extra with the 5 L jug.
I sometimes see 4.4 L. Why do they make it that size? Is it shrinkflation?
Because they can?
I was confused when I bought Aisin branded CVT fluid and it came in... quart containers. Of course it drains something like 2L precisely when I do a drain and fill...
4.73 Liters = 5 quarts, and most packaging these days state that.
Where do you find 5 Liter jugs?
In Canada. Pennzoil and some Castrol grades come in 5 L. It says Made in Canada on them. M1 is always 4.73 and says USA, so I assume it depends on the country it was blended.
Pennzoil and M1 are the same price, but since the Pennzoil is 5 L, it is technically cheaper.
In Australia they sell 5L and 6L jugs. They are usually priced so that $ per unit volume is effectively the same, it’s just that 6L is a more convenient size for many modern engines.
For some diesel engine oils, they also sell 10L cubic jugs, which are usually priced a bit more economically.
Here's a twist:
In Canada, SuperTech either comes in 5L jugs or 946mL bottles; both made in USA 🇺🇸
Valvoline and Quaker State are also sold in 5L jugs in Canada.
When I had my 2000 Civic I liked having the 4.4L jugs up here because that engine didn’t burn oil (not until much later) and I could just put the entire 4.4L in it (slightly overfilling but not by too much) I haven’t seen any 4.4L jugs in a long time but it used to be common up here for a while.
I think Kirkland might be 4.4 L or the Castrol sold at Costco. I can't remember which one
Were using Mobil Super perhaps?
Here is a pic of a 4.4 liter jug of the US Castrol Edge with the Dexos approval presently available at Canadian Tire.
If I remember correctly Walmart Canada uses 5L jugs for the major oil brands in most popular viscosities. Then there is another big box store called Canadian Tire and they sell in 4.4L jugs.
Like I mentioned above it’s done to avoid price matching.
All the other smaller automotive retailers, like Napa, Parts source etc. sell in the 4.73 or 5 quart volumes presumably because they don’t have access to their own container supply, so they use the US containers.
