Originally Posted By: MrWideTires
Originally Posted By: dparm
You should be running what the manufacturer recommends. Nissan isn't stupid, and they certainly don't specify 91+ if the car runs the same on 87. I'm betting your knock sensors are pulling the timing.
It's the same engine that's in the Altima, and it recommends 87 in the Altima.
I tested my MPG on both fuels several times, did not change the slightest bit.
If the timing was retarded, it would not be putting down the power it is putting down, or running as cool as it does.
I know Nissan knows what they are doing but after coming across and reading some many horror stories with the QR25DE motor (excluding the new Spec V), I'm kind of skeptical. I've never seen so many low mileage motors replaced because of precat failures and butterfly screws coming loose and scoring cylinder walls.
Poor crank sensor, head gasket, and piston ring design were some of the other common problems.
I don't think using 87 in a car that recommends (not require) 91+ is a problem. If I recalled correctly, the manual stated something to the extend that using 87 in the 1.8-2.5L Sentra was acceptable. Use 91+ for better performance. Said the same thing in my gf's 98 Maxima GLE which specs for 87.
Don't you think "better performance" is a rather vague term especially in a car that has a 9:5:1 compression?
