Buy a bunch of ammo and see what shoots the best.
Are you providing the ammo to play with? LOLBuy a bunch of ammo and see what shoots the best.
It's not playing it's testing.Are you providing the ammo to play with? LOL
In my experience, there are few off the shelf rifles that can achieve this degree of accuracy. Regardless, this level of mechanical accuracy is rarely needed in a hunting rifle, especially in New England where thick woods limits shots to much, much shorter ranges than out West.It's not playing it's testing.
With ammo the gun likes it should be able to do holes touching at 100yd all day.
Yeah 7.62x39 with hunting ammo is plenty for little east coast deer at east coast range.In my experience, there are few off the shelf rifles that can achieve this degree of accuracy. Regardless, this level of mechanical accuracy is rarely needed in a hunting rifle, especially in New England where thick woods limits shots to much, much shorter ranges than out West.
The garand was designed for 174grn fmj at 2700 fps.As long as it's a bolt, use whatever you like. I would go 150 for deer, as others have said.
For a Garand, however, you need to watch the pressure. So much internet hogwash around. No, you won't "bend the op rod" because it already has a couple bens in it, but yes, you do need to watch the pressure, or the bolt hits the heel of the receiver too hard. Enough of that, and you crack the receiver.
Then you might as well sell the rest of it for parts.
So, if you got a Garand, stick with 150 grain. Or get an adjustable gas plug and dial back the pressure on the operating system.
Where did you get the idea that I have learned about Garands from the internet?The garand was designed for 174grn fmj at 2700 fps.
It's not as fragile as the internet leads you to believe.
WelcomeThe garand was designed for 174grn fmj at 2700 fps.
The receivers cracked because they were thinner at the rear due to modifications and using a harder steel that caused them to be brittle.Where did you get the idea that I have learned about Garands from the internet?
I own several. Built a couple from the receiver up, including one at the CMP. Talked with the armorers during my 4 days down in Anniston.
And have several books on the rifle.
It’s not bullet weight that matters, as much as pressure in the system, and my advice is conservative because the rifles are antiques, and collector’s items. The US Army didn’t care about a few cracked receivers, when they had over a million in service, and millions more under contract.
And they did crack a few, back in the early days, before M2 ball was adopted, which is why you see so many lead-dipped receiver heels from around the 1 million mark.
But while the Army didn’t care, with bare receivers getting over $800 each these days, the modern collector would care if it were their one receiver that was cracked from excess bolt speed due to excess pressure. An expensive, and completely avoidable, event.
I never said the rifle was fragile - I recommended a load that I know will be within the pressure limits.
Ty sirWelcome
We should probably start a separate thread on this topic, as the OP was looking for a very inexpensive rifle, and put a very inexpensive scope on it, and you and I are going down the Garand rabbit hole, which I find fascinating, but which the rest of the folks on this thread might not…The receivers cracked because they were thinner at the rear due to modifications and using a harder steel that caused them to be brittle.
The lead dip was for the early harder receivers.
Once the steel changed they stopped dipping them.
Pressure in the system isn't really the main issue since it's a very lossy gas system and it's at the end of the barrel.
The real areas for concern are properly lubricating it and keeping the oprod spring at least 19.5" long.
There is no bullet weight restriction and if your rifle is in good shape you can shoot any SAAMI spec in it with no worries.
I never heard that before regarding the Garand. I'd be worried about loading a 240 grain SMK bullet for use in mine.There is no bullet weight restriction and if your rifle is in good shape you can shoot any SAAMI spec in it with no worries.
Zero reason to worry.I never heard that before regarding the Garand. I'd be worried about loading a 240 grain SMK bullet for use in mine.
Interesting, how about the twist of the barrel for something that heavy?Zero reason to worry.
Lube it correctly keep your spring in good shape.
The USGI barrel has a 1-10 twist that dates back to when the 220gr bullet was in use.Interesting, how about the twist of the barrel for something that heavy?
It’s not so much the pressure but the slide velocity. Slower burning propellants used in cartridges intended for heavier bullets increase the time and area under the pressure curve which imparts a higher velocity to the slide. The constant battering of the slide will eventually distort the slide (bending, sort of…) causing bolt locking and binding.Where did you get the idea that I have learned about Garands from the internet?
Good advice on not dropping the slide on a chambered round.It’s not so much the pressure but the slide velocity. Slower burning propellants used in cartridges intended for heavier bullets increase the time and area under the pressure curve which imparts a higher velocity to the slide. The constant battering of the slide will eventually distort the slide (bending, sort of…) causing bolt locking and binding.
Hornady, Prvi Prtisan, and BlackHills load Garand safe factory ammo.
Reloaders can duplicate original milspec ammo using powders approximating the burn rate of original powders and avoid problems.
Another more important consideration is PRIMERS!
High primers or overly sensitive (ie: Federal especially) can and will cause a slam fire out of battery.
Never, Never EVER drop the slide on a chambered round, or a loose lying round. Always use a clip, either a single shot adapter, or 2,5, or 8 shot.
Don’t ask me how I know!
A busted stock and chipped reciever at the bolt lug recess is all I suffered…
I own two Garands and have shot CMP competition. Also attended the armorers school. My older brother shot NRA. Competition back in the ‘80’s and I inherited his match rifle when he passed away.
My preferred load is a Speer 168gr HPBT match bullet over 46.0gr of either H4895 or Shooters World Precision Rifle. CCI primer in match prepped brass.
My CMP “special” with a Criterion barrel in a replacement Boyd’s stock will come ver close to the full blown match rifle. It’ll hold the 10ring at 600yds. With match ammo.
If only I could!
