GON
$175 Site Donor 2026
A few comments on PEX. There are three types of PEX, A,B, and C. B is typically what you will find at Home Depot and Lowwes, and uses crimp connections. PEX A has zero crimps, you simply expand the tube, using a tube ex pander (made by Milwaukee) and then it goes back in place. A seven year old can make a perfect PEX A connection.
After doing much research, I went with PEX A a few years ago, replacing copper that would get pin hole leaks, likely due to water quality. PEX A is simply awesome, and simple. Youtube has multiple videos on PEX A. A bit harder to find, but well worth it. Menards does carry PEX A.
