So I went from M1 Advance Fuel Economy oil to Extended Performance in the same weight and I cannot hit the same MPG I was getting under the AFE oil. I literally drive this car to work and back, same route etc. I was religiously getting 39.5 going to work and 41 coming home. I’m guessing because of the hills…
Anyway, is this because the EP oil is ‘ thicker ‘ or something? Very odd for sure, but one of your guys maybe be able to explain it.
I get that the oil touts better MPG , but this might be an actual instance where you DO gain some MPG. The AFE oil seemed thin, does that mean less wear protection? I plan on following the OLM as stated in the manual. That’s debate aside, that’s why I went to the EP variant versus the AFE flavor.
Thanks!
Thanks!
